Originally Posted by
TomCrump
If it were me, I wouldn't use either.
Minwax Polycrylic will turn to goo and any Krylon product, that I've used, won't hold up to raw gas.
I've been using Minwax Polyurethane, in aerosol form. The polyurethane will not turn to goo when exposed to raw gas. I do clean it up as soon as feasible, however.
Other than the delivery system (aerosol, solvent, water) is there any difference between the Minwax polyurethanes? Are any of them more resistant to gasoline or glow fuel? Is the oil modified water-borne Minwax polyurethane any better or worse than the Rustoleum product? What are your preferred products for glow fuel resistance, taking from your comment above that spray Minwax polyu is your choice for gasoline? thank you very much.
Sincerely, Richard
