Hi Brandon,
I wouldn't recommend the 55RA. The 35 will provide all the power you need for this model, anything more is overkill plus bear in mind ESM fuselage are polyester resin not epoxy, poly gets brittle with time and UV exposure. Plus the wing structure is weak (see many posts earlier in this thread), and you get the point.
