RCU Forums - View Single Post - Need help to fix problem with a trailing link gear strut
Old 10-12-2016 | 06:43 PM
Crazy4Flight's Avatar
Crazy4Flight
My Feedback: (540)
check first if there is any clearance between the link and strut, it may be binding there
remove the set screw from the link, then you drive out the pin, use a drive pin punch (flat on the end)
the hole in the link should be slightly bigger than the pin .002-.004"so it can pivot
