Erez,
It would be worthwhile to check that the lines ARE the length you want. Years back, several manufacturers offered lines by the diameter and length they marked on the packaging. Not all were the specified length; many were several feet longer. For a smaller CL model, the difference between, say 52.5' and 60' feet or more can make a difference! Brodak has a fine reputation for quality so this should not be an issue, but I'd still check to assure confidence. (Sorry, if you think in meters, you'll need to convert...)
