Originally Posted by
Gizmo-RCU
Jack,
I use LIFE and have never had any problems. Most Servo's today give values for both 4.8 and 6 volt performance . Guess if you are using really old servos there could be a problem? I know several
local guys that are really anal and would not use LIFE on some Servos that were old enough that only 4.8 specs. were available. Did some research and found that the higher values were fine and current
information was available by inquiry to the vendor (Futaba in one case). I recently gave a friend a Smoke Pump nib and he installed it and boy did it put out, and then failed. Read the small print and it was for 4.8 volt,
The pump had been in my shop for years............
Thanks. I was worried about some old Futaba servos I have, S128, S138, and S148. They all have 6 volt ratings, but I'm just uncertain about the fully charged voltage of the LiFe.
