Hey Henning,
With your setup your Motor and your ESC should run very cool.
It's likely that the ESC seems quieter because it has to commutate the Pyro motor at close to 7khz, whereas with the Advance it is probably closer 1.5khz, which is right in the middle of the range that human ears are most sensitive to.
Brenner ...
