RCU Forums - View Single Post - nitro force engine
Old 10-18-2016 | 05:05 PM
cbaker65's Avatar
cbaker65
Originally Posted by Skydive2144
So today i broke in the engine on my tamiya nitro force. I ran 5 tanks of fuel through it without going full throttle. every time i started it it started on the first time and ran great. i brought it in, then about two hours later i went out to use it again. it took a few pulls to get it started and as soon as i hit the gas it stalled. i started it again and let it warm up for about a minute and it took off fine. when it ran out of fuel, i put more in and when i went to start it again the pull chord felt stuck. if i slowly pull it up it takes some force but it will come out and the engine will turn over. if i pull it hard enough to start it its gets stuck and it feels like im going to break it before the engine turns over. Does anyone know what could be wrong? Id like to get this fixed tonight if possible, i am dying to use it.
The needle bearings are probably getting wedged on to the starter output shaft ,if the o-way is in the pullstart housing itself ,then pull it off
an put a couple drops of oil in the o-way bearing.
Also,your engine is still tight ,you can loosen up the glo-plug a little before you start engine ,the once it starts up ,pull igniter off
an tighten it back up while engine is running. This helps relieve the pressure on the starter on first start up,acts like a compression release!
