RCU Forums - View Single Post - Help needed
Thread: Help needed
Old 10-19-2016 | 12:01 PM
David Bathe's Avatar
David Bathe
Originally Posted by kenh3497
Now it will be which ESC, motor timing, battery, how much brake, and I think there are soft mounts for electric. Me thinks you jumped from the frying pan to the fire
Ken
Oh.. you believe it.
Watt inferiority is reaching critical proportions. Like nothing I'd every experience with IC.
I've just read a 16 side thread discussing the pimping of a real cheap/small RTF F3A that I also happen to own. So much uffing and ahhing about the simple cheap no brand prop supplied. 15 sides later with many expensive props, custom props, modified prop ordered and tested by owners and thread subscribers... around the world... The the conclusion was that the prop supplied... was the best! Now they've moved onto the ESC... same story, buying this, testing that. In the mean time, I'm have a blast.
