RCU Forums - View Single Post - Looking for advice on a first tank purchase
Old 10-20-2016 | 12:50 AM
Domi898
Originally Posted by CaptainB
Hold on old chap - You mentioned that you want to run the tank indoors over winter. Be careful with metal tracks - they can really score your flooring up if it's wooden and can lift carpet in a turn. Also, remember these are mechanical machines and have grease and oil in them in various places which can also make a mess. For an introduction to RC tanking both indoor and backyard running, the standard newest HL tanks will more than suffice. The T90 is indeed a good option but any of the latest HL tanks (Challenger,Abrams,) are all good as standard.
Good luck
CaptB
Oh wow I hadn't though about the potential consequences of running metal tracks on our flooring indoors... Seems getting the standard version for now would be the best bet and then look at metal tracks for next summer, at least we'd have both available.
Originally Posted by jarndice
There was a time when Heng Long were what you would expect from a Far eastern Toymaker,
Times change,
The latest 2.4 digital Heng Long Radio Control Tanks electronics are coming up to the standard of aftermarket control boards, They aren't there yet but they are miles better than they used to be,,
The ABA used in the construction of the Tank is sturdy and not at all fragile like the plastics of yore,
Where I would be looking is the Gearboxes and the smoker.
Certainly if you are confident enough to do a little tinkering then I would unplug and unscrew the Smoker and replace it with a "TARR"/1/2/3/4 depending on whether you want a metal body or plastic Proportional smoker or not,
A Taigen 4/1 or 5/1 gearbox would be my first choice in replacements,
Again simply unplug and unscrew, of course you will need to remove the tracks but that is easy enough.
After that you should have a Tank that will wipe the backside of the pain across the road.
The gearboxes should be readily available from IMEX in Florida, but I don't know of an American source for the "TARR" Smoker I buy mine from ---
www.rctankelectronics.com
And click on Store for details on the differences between each one,
And remember with the £ dropping faster than Donald Trumps popularity now's the time to buy from a British dealer!!
Oh and welcome to the world of Radio Control Tanks.
Shaun.
Thanks for the advice, your right about the £ atm and with brexit looming it will only get worse. I'll add the gearbox and smoker as top priority bits to grab first, would I need to worry about the plastic tracks if I add the metal gearbox first?
Was gonna use http://www.hayaltd.co.uk/ to buy the tank, they seem to have the best price and from what I can tell they are located on ebay as well so I could order through there and have little bit of protection.
