Resistors on motors
I just swapped out the gear boxes with Taigen V2 in my ZTZ99 with a Taigen radio setup and one motor would not run. Put the meter on it to test for voltage and it will run just fine. Looks like it needs a resistor across the poles for the controller to work. Has any had to do this and if so what resistor did you use?
Jimmy
