Originally Posted by
Gaspar
Distance should be always measured from the center of the pads when the plane is on the weight sensors.
Gaspar
Thank's Gaspar,
Of course I'm going to measure from center of the pads, but with sink gears (shock-absorber) the distance is about 30mm more if fix gear in free position and put to the pads. What about I worried will that affect to CG?
Example:
distance from main pads to CG -100mm (wheels absorbed) and for right CG needs to add 50gr- right balanced aircraft.
with wheel fixed in free position the distance - 70mm, and it's required to add less (about 30gr) weight- rear balanced aircraft at the end.
Or these will not to affect to balance critically?
Kind regards,
Sergey
