What motor controller are you using? The Taigen motherboard will drive the motors no matter filtering is on there, I just tested with caps (pre V2), the V2 motors (board with filtering built in on the end of the motor), and also a 380 motor without any filtering and it drives them correctly. Which motor are you using?
