Well got it figured out. What I found was a cold solder joint on the black wire on the motor. It was soldered to the end plate ok but not at all to the tap going into the motor. What was happening is when I tested the voltage it was completing the circuit. Will fix it in the morning. Could not find my solder.
Jimmy
