RCU Forums - View Single Post - trying to identify a 15-20 year old Decathlon (kit built)
Old 10-25-2016 | 10:45 AM
foodstick's Avatar
foodstick
Default trying to identify a 15-20 year old Decathlon (kit built)
I was given this plane by a friend, His father built it 15 -20 years ago.. here are the specs..
64 inch wing span
45 inch length
11 inch root rib
This plane had been hanging for years and fell to the concrete garage floor. So after converting to electric I also had to rebuild and paint the cowl,wheel pants , and scratch build wing struts. there were other repairs along the way , and I changed some of the servo installations to what I am used to. I have the cowl split..with paint drying right now.It is setup so that the bottom cowl clicks on with alignment pins and magnets..and allows access to battery changes.
If anyone knows the proper CG I would love that info as well !
Also using a 6 cell 3650 Lipo I am looking at an all up weight of 6 3/4 pounds. Without a fully put together balance I am pretty sure its close and a bit nose heavy as is.
I know typically the balance should be in the 28% of chord..so I will go with that if nobody knows the actual kit numbers.
