LSN is most likely too lean. Also make sure you have the right size prop, too small a prop can affect the idle in the gas engine. One other thing to check is the filter screen, you pull the cover off the carb and there is a screen in there. there could have been some gunk in the tank that got sucked in to the carb and cause some blockage.
