Originally Posted by
porcia83
There isn't a protocol out there that can't be hacked. HH not commenting immediately is nothing surprising or shocking in any way, . Perhaps what worked for the military public relations machine back in the past doesn't quite fit modern day communication standards. Chances are they will actually research the issue and give a well thought out response rather than just issue an immediate comment. A lot goes into media releases, even more so when it can/might have an effect on the bottom line.
As far as sending a a high level signal that overshadowes the legitimate signal otherwise know as jamming yes all protocols can be jammed. But as for hacking a proper designed system that should be extremely difficult
and only by using equipment not readily available to the average person.
