RCU Forums - View Single Post - Kingtech Gen 3 Question
Old 10-27-2016 | 04:59 PM
dccatl
Originally Posted by gunradd
Hello Dave
I do the same on all my installs and this is a very good practice. If this is the Xicoy ECU I can help you. If its the new ECU I have no clue and you should give Barry a call. You said gen3 so I assume this is the new ECU. Some Gen 3 K210s still have the xicoy ECU so that's why I ask.
Could you please explain how to do this with the xicoy ecu. Is running the test/prime pump from the test menu all that's required to run it at max voltage?
David
