RCU Forums - View Single Post - Honda GX 31 four stroke thoughts....
Old 10-29-2016 | 04:27 PM
  #50
Jim.Thompson's Avatar
Jim.Thompson
Originally Posted by av8tor1977
One thing is, I converted it to electronic ignition.
I am planning on doing that too for sure.
As such, I probably used my "lazy trick" of coring out the center of the magneto, trued it up in the lathe, then just made a simple screw on prop hub to screw on against the magneto center. ....
I have wondered about doing that. Seems a good idea. How does the prop hub "screw on against the magneto centre"? Do you use a centreing spigot and six axial countersunk machine screws? Placed 30 degrees different to the six prop retaining bolts?
I then make a collar to hold the magnet for the ignition that goes over that magneto center, and is held with a set screw for timing adjustment.
.......................................AV8TOR
Got that bit. Very good! Thanks again.
