Dude if your NIMH packs are 10 years old there shot trust me no wonder why you have no power or punch with your tanks a 10 year old NIMH is beyond shot and its life was well over..
if your packs are 7.2v 6 cell and when they charge if they go over 10 volts when they peak charge there done for. A 2S ipo will be far much better! and they charge at high rates and can be charged many times faster than NIMH packs if your lipo has a high C rating. normal lipo is x1C 3000 = 3amp charge but you can easy go 2 amp and with high C much more so they charge much faster than NIMH[TABLE="width: 100%"]
[TR]
[TD="bgcolor: #f0f0f0"]
SPECIFICATIONS[/TD]
[/TR]
[/TABLE]
Capacity: 3300mAh
Rated Voltage: 7.4V
Max Charging Current: 6.6A
Max Continuous Discharge Current: 30C (99A)
Burst Discharging Current: 55C (181.5A)
Watt Hours: 25Wh
battery specs from above 3300 lipo with charger see you can charge at higher rate so it will charge more than 2 times faster than a 3300nimh pack, See above this 3300 lipo can be drained continuously at 99Amps your old NIMH packs probably cant handle 10 amps!
Originally Posted by
pcsguy88
Nice. Not sure when I'll make the switch since it ain't broke and I still get 45min run time out of each of my 10yr old NiMHs and they charge in 30min.
That's T-90 money.
