Originally Posted by
arneg
Did some measuring of the cowl today; the inside diameter at 3inches from front is 230mm /9.055" sideways, it is a bit oval so bigger top and bottom. From firewall to front of prop.flange there is 164mm /6.46" . some rework for 34mm needed as the engine is 200mm long
Thank You, for taking the time to do that for me. I believe it will be a tight fit, but should work.. I will order one as soon as they are available State side.
