Originally Posted by
Craig B.
Hi Carsten,
I thought I read somewhere in the futaba literature that the leads should be no longer than 30-40 cm.....or maybe I was told that by our local futaba agent?
SBus is intended to be able to drive servos in the tail with a single cable while the receiver is in the front of the fuselage so it needs to be able to drive cables at least as long as the typical fuselage. It wouldn't be of much use if it could only be used to connect servos within 40cm of the receiver. Connecting between receiver and powerbox is the same as between receiver and servos..
