Originally Posted by
Craig B.
Hi Wayne,
I was was speaking of the leads from receiver to powerbox, not sbus lines to servos. They quite obviously can be very long.
If it's a Futaba receiver I was assuming a serial (SBus) connection between the receiver and powerbox. If that isn't the case then sorry for the confusion. If the receiver does connect using SBus that is a serial, digital protocol and the Powerbox uses the same signals/data as an SBus servo and should be able to use similar cable lengths.
