Originally Posted by
pkoury
Futaba sells longer antennas that would allow you to keep your receivers where they are and just run the longer antenna leads. Futaba part number -HSP79766 ANT 400MM. You can also purchase a cable that can be used for 2.4 antenna from Digikey
http://www.digikey.com/product-detai...554-ND/1657749 they would need to be cut to the length you need and the shielding cut back on the tip. These antennas are coax cables on most Futaba receivers and just plug into the receiver.
Those longer antenna cables and antenna extension cables (even the Futaba ones) come with an associated and not insignificant signal loss. Its much better to move the receiver to a location where the antennas are more clear than to extend the antenna cables...
Bob
