Ok so today was a good day I was able to taxi test the jet and all go good the jet tracks ok just little sensitive to stering ,I was not able to maiden the day just go so fast and the sun was so low most guys stay n the ground and maybe this turn to beter day because when I was pumping the fuel out from back to the fuel jug the center tank stayed 3/4 full the clunk was suspended up in the tank so this is next to fix before the next attempt to maiden ,the surfaces are changed to flaperons and tailerons and I have no idea if this will work just watched some videos on YouTube with f-35 and this is the full scale jet setup so maybe it will work for the model?
