So the nose gear door are no more problems the converted into two .on the main gear I have done same as you cut away all the fiberglass so the tires clears in with no problems. I'm just hoping that the fuel tanks change will not cost some problems but the in the cg and when full the cg don't change much just a little bit nose heavy but nothing like when the center cell was in the front of the former hope this will not cost the jet to be tail heavy or not stable.
