Originally Posted by
Joystick TX
This whole issue could be solved if the manufacturer would admit that their manuals, for both the DLE 30 and DLE 35, are wrong, at 46 degrees, and just list the correct timing, of 28 degrees, for their engines. An 18 degree difference is not insignificant.
It would also help if the repair shops, like Hobby Services, would admit that they are NOT setting the timing at 46 degrees.
I don't know how you can get 46 degrees BTDC on a DLE 35 without redrilling the sensor mounting holes, or re-keying the prop hub. It would be interesting to see a video of how they are getting that timing.
This issue has been going on for years and it is insane.
The Manual included with a new engine that goes through Hobby Services was written by someone at Hobby Services. Look and see whose name is on it? The address - Champlain, IL.
