RCU Forums - View Single Post - How to 'glass wing join without clogging torque rods?
Old 10-25-2003 | 01:54 PM
rik756's Avatar
rik756
My Feedback: (12)
Default RE: How to 'glass wing join without clogging torque rods?
I'm sure there are dozens of different opinions but just to put up one more you might also try just usins thin CA to glass it. I attached a sketch of how I did mine when I glassed it.
I used 4" wide med tape and started the leading edge of the tape just behind the torque rods and cutting two small holes in it to go over them. I tacked it down and pulled it tight as I glued it in one long strip all the way around back to the torque rods.
Again I have used both ca and epoxy. The CA seems to bond just as well but leaves a gritty textured surface. The epoxy smooths out allot better but it's harder to pull the tape tight, keep ut from bubbling and get it smooth. (IMHO). The CA also saves some weight if thats a concern. Just a thought.
