The hart of the build is the Summit powered transmission that is fitted to a Carbon chassis plate that I screwed to the plastic cage. I also glued it so that the screws don't get stressed out. This made the chassis very stiff. I also did it to the front so that the servo would not flex the chassis. I installed the L.E.M Dog Carrier in the transmission so that it would keep the gears from walking inside.
