RCU Forums - View Single Post - turbine choice
Thread: turbine choice
Old 11-20-2016 | 08:21 PM
Springbok Flyer's Avatar
Springbok Flyer
Both are very good engines, but if you want to use telemetry with your engine (I assume it will be a new one), then you must first check if the ECU will be compatible. All the Xicoy ECU's are fine and will give you telemetry options on all radio systems.
Jan
