Originally Posted by
2walla
The 140 JM is nearly 1 lb lighter than the KT. Brushless on the JM doesn't do much for me- It will last longer, but is more expensive. For a flash I would go for the lightest weight install. The new KT pump self priming valve on the pump doesn't do much for me either.. just something to clog/plug and cause an issue. with the old pump if get some air in the line it might not start the first time.. if the purge valve screws up on the new one you are potentially down for service..
The ability to run diesel is nice.. I am sure the JM would drink ok it but they don't recommend it so whatever that is worth.. I like to be able to dump my fuel in the tractor if gets too old...
This info is incorrect. Kingtech has a new K140 out that is smaller and lighter then the old one.
JM140 is 3.2 lbs installed Dreamworks price $2995.00
K140 is 3.5lbs installed Kingtech USA $2290.00
So the difference is 0.3 pounds.
They are both fine engines. I like the fact at most of the bigger events in the US Kingtech attends and has spares if needed encase of problems. nothing worse then spending a ton of money to go to an event and have a problem. Also Dirk or Barry will usually pic up service calls even on the weekend.
