Originally Posted by
kelly vallee
I would like to know what size of air cylinder are you using for the front gear door?
I'm guessing most are using what they have on hand, that's what I did! You don't need a lot of stroke. More strok is better then less as you set the door at full open with full extended strok on the cylinder. When closed the cylinder does not have to bottom out. I'm guessing 1-1/2" to 2" stroke.
TB
