Originally Posted by
coxco
Hi Coxco,
I've recently bought two Spektrum A5060 Mini HV Digital Hi-Torque MG servos for my Mustang and I find that they are noisy when idling in the centre position. They are making a random 'clicking' noise even though there is no load on them – even with the servo horn removed. They don't seem to move with the clicking noise, but you can feel it slightly through the casing of the servo if you hold it. Other than this clicking noise, they seem to work fine.
I've not noticed this with other HV metal geared servos that I have and I wondered what was causing it, and if it was a problem. Will it cause premature wear in the servo or excessive drain on the battery? I've tried the servos at 6v and 7.4v and with different receivers but it doesn't make any difference, the clicking noise is still there.
Thanks and Regards
Pete
