Originally Posted by
tomhugill
Could you elaborate on the mistakes one can make plugging in a flash unit that will cause it to fry?
Also so please explain how an ibu is sub optimal for ir battling? I use them and I use Tamiya and both have the same stick layout both can use a Tamiya tbu and it emitter and our testing shows the same range with both.
It would be hard to do with the flash plug but the MG led and IR led if plugged in the wrong way reverses voltage and can blow the bulb.
