Hi Gary,
Question, did you specifically order your electron landing gear for the Ultra flash? I had a brief discussion with our local rep her and apparently the UF combo from electron is designed around the models weight. It was also mentioned that should the springs be too hard you can replace the springs with softer ones? He did mention that he doubts I will have an issue. I only asked this as there have been a discussion around this recently
What surface will you be landing on? W very fortunate here in Dubai having a really long run way. the bounce you referring to has a number of factors. I'm no expert and this is my first jet build but just my 2c worth.
