Originally Posted by
wblombard
Hi Gary,Question, did you specifically order your electron landing gear for the Ultra flash? I had a brief discussion with our local rep her and apparently the UF combo from electron is designed around the models weight. It was also mentioned that should the springs be too hard you can replace the springs with softer ones? He did mention that he doubts I will have an issue. I only asked this as there have been a discussion around this recently What surface will you be landing on? W very fortunate here in Dubai having a really long run way. the bounce you referring to has a number of factors. I'm no expert and this is my first jet build but just my 2c worth.
The electron 40 EVo suit the flash , you will need to open up the mounts to suit , it took me 1/2 hr for each mount , I used the Electron steering set , this you will need to open up the front former to allow the steering tiller arm to have full swing - simple dremel work
