I have needed these in the past and I modified thumb screws by simply cutting off unneeded material on the ears of the screws to the same width as the screw diameter, drilled a hole in the middle of the left over portion of the thumb screw, screwed them into the blind nut or threaded insert and attached the wing struts to them; Lowes or Home depot sells them.
