Having the slipper clutch set properly might save some wear and tear on the spur gear. Maybe check into an aftermarket metal motor mount. Is your motor adjusted with a cam style setup? I know on one of my RCs, that has a plastic mount; using a 1/8 scale sized motor will twist the mount excessively...ends up with spur gear shot in no time.
