Ghostrider
I went out of my way to make sure no reasonable person would take issue with my inquiries! I have had several phone conversations early on with Dirk and he has always been straight up with stuff! There has been no discussion as of late as to the status of the T1 factory that Dirk cannot control! I simply asked for an update! My comment about the positive responses ment two things:
1. All the "positive comments" meant this had to be a great aircraft!
2. He is definitely monitoring the the T1 threads and as such I did not need an immediate answer as I stated in my last post! You know nothing about me or what I know so I will ask you to reframe from making the assumption you do!
If you miss interpreted what I posted I would appreciate a statement to that affect and will attempt to be more clear. If that is not the case, I am politely asking you to not reply directly to my posts and I will do the same!
Pattratt
