Originally Posted by
shenlonco
Thanks, but shipment would be quite expensive... and i also want to glue metal parts to the plastic.
jarndice
Hi, Olaf, the latest Heng Long Tanks including the ABRAMS are made using ABS,
The older models were of a more fragile Plastic.
Do be aware that if you need to use a debonder those used on the old Heng Long Plastic is not as good on the ABS.
Shaun.
Hi Shaun,
Sorry but i dont know what you mean by using a debonder ?
English is not my native language
For glueing i thought to get Loctite 435, combined with a primer it should go with ABS !?
