Regular CA glue should work for you.
Originally Posted by
jarndice
Hi, Olaf, the latest Heng Long Tanks including the ABRAMS are made using ABS,
The older models were of a more fragile Plastic.
Do be aware that if you need to use a debonder those used on the old Heng Long Plastic is not as good on the ABS.
Shaun.
