I have everything you need as I had to retire a Pegasus KC from a bird strike in air, IT would be the carbon pieces and aluminum blocks and ears ready for straps, I have straps to but you should have those. I also got flex plates, I am headed to swap meet so it will be late tommorow before reply, make me an offer to motivate search.
I also have a Zero time Pegasus SP 30lb thrust, Air start original ECU that has zero time on it with the upgraded TC that does not need the hook bend. $1500 OBO
