Originally Posted by
donnyman
Your working on a super WHAT?
As far as a first build go's it will depend on what you prefer and you flying skills ................for starters may I suggest the SIG Kadet series.
Pretty sure he meant Cub.
I agree, an LT-40 would be a perfect first kit. They go together quickly and are easy to modify with very little work or skills. A bolt down wing is an easy mod that only needs a couple pieces of 1/4" ply to be cut and a couple dowels, which are already supplied in the kit. Making it a tail dragger is a little more complex, and if you are a beginner, better to stick to the trike gear.
