Originally Posted by
TonyBuilder
So back to my gear issues. Does anyone know who makes the gear? Currently parts are not available short of getting a whole complet set (witch I may have to do!). My issue as of late is the springs on the mains have lost there "spring", at rest the gear will no longer hold the plane up, the gear is compressed all the way and if you lift the wings they will rebound but once you start to roll they collapse and bottom out and won't rebound.
I took the the right side apart as it is the worst. The spring is .310 O.D. and 2.77" long.
The amount that the strut moves inside the main post is about 1/2" so the spring does not compress much until the strut bottoms out. I added a 3/8" extension spring to pre load the spring for now but that is just a temp fix.
I am working with Century Spring Co. out of California to get a custome replacment sring with a bit more holding strength.
TB
if you get some let me know I'd like to order a set too.
