You say it is a late model, so have you removed the excess radio aerial stowage tube ? it runs alongside the engine grill on the drivers side.
The one on the opposite side is correct and can be left untouched,
Have you fitted a radio aerial beside the Turret just by the edge of the Tank body immediately in front of the engine grill on the machine gunners/Radio operators side,?
Have you removed the two headlights from the top and fitted a single headlight in the centre, between the drivers vision slit and the Radio operators machine gun ?
The exhaust pipes on the late model Tiger 1 are without the semi circular covers but have a much smaller cover ,
The whole of the Feifal Air cleaner system should be removed
The Starting handle on the late model should be in two parts and be placed near to the Radio aerial and a Fire extinguisher should be mounted on the Radio aerial side of the Tank on the Engine grill,
The late model Tigers loading hatch is smaller and the rear mounted turret ventilation cover should be moved to the front centre of the turret,
There are many other alterations you could/should fit/fix but for that you need a good reference source.
Shaun.
