RCU Forums - View Single Post - Need help with receiver hookup
Old 10-25-2003 | 09:33 PM
DBCherry
Default RE: Need help with receiver hookup
If you don't have a red plug comming from the switch, you want to plug the single connector into the receiver. (One side of the switch has two wires, the battery plugs into one, the other is for charging through the switch harness; the other side of the switch is the one tha plugs into channel 7.)
You did buy a Hitec receiver that's compatible with Futaba right?
Dennis-
