RCU Forums - View Single Post - Brand New DA 60 problems
Old 12-08-2016 | 10:50 AM
Truckracer
My Feedback: (19)
Not sure about what you're saying about the ignition. DA ignitions require the prop be flipped briskly to produce a spark (I believe the 35 ignition is an exception) so rotating the prop slowly probably wouldn't produce a spark.
If you feel there is an ignition problem, you have parts on those other DA engines that could be swapped out on the 60 do prove the 60 ignition is good or bad.
