Easy to land. But poorly developed turbines with a high idle thrust make it difficult to slow down. Incorrect AB set up (needs to be 85 degrees) does not add enough drag.
You cannot fly it into the ground, it has main wheels on the balance point, so will bounce if you 'force' it.
Hold it off till it lands, it will not drop a wing!
I have had several Harpoons and Rookies and loved them all.
