RCU Forums - View Single Post - Latest Heng Long Electronics Swapping
Old 12-13-2016 | 04:15 PM
  #46
shenlonco's Avatar
shenlonco
Originally Posted by Sky_HawK
I haven't seen the motors separate. I want to install 400's and heatsink the MFU, just because I can lol. More torque is welcome now that the drivetrain will handle it. Just need to brace the idlers and get metal tension arms.
They sell 390's on e-bay that are not to expensive for the HL tanks they say they are more powerful and faster than stock and you must use metal gearboxes.
http://www.ebay.com/itm/2-PCs-Upgrad...UAAOSwstxVbetu
Description:
Item Name: Brushed Motor
Power Cable Length: About 15cm
Diameter: About 27.36mm
Length: About 51.22mm
Shaft Diameter: About 2.3mm
Shaft Length: About 11.93mm
Motor Gear Diameter: About 7.02mm
It is the second generation brushed motor, featuring 3 times torque force and rotation speed.
It is suitable for mainboard of 1/16 RC Tanks, German Tiger, German Panther, Soviet Russia T34, Chinese Type-99, etc.
[TABLE="width: 500"]
[TR]
[TD="colspan: 2"]Voltage[/TD]
[TD="colspan: 2"]No Load[/TD]
[TD="colspan: 5"]At Maximum Efficiency[/TD]
[TD="colspan: 3"]Stall[/TD]
[/TR]
[TR]
[TD]Operating Range[/TD]
[TD]Nominal[/TD]
[TD]Speed[/TD]
[TD]Current[/TD]
[TD]Speed[/TD]
[TD]Current[/TD]
[TD="colspan: 2"]Torque[/TD]
[TD]Output[/TD]
[TD]Current[/TD]
[/TR]
[TR]
[TD="colspan: 1"]4.5-9.8V[/TD]
[TD]6.0V[/TD]
[TD]r/min[/TD]
[TD]A[/TD]
[TD]r/min[/TD]
[TD]A[/TD]
[TD]g.cm[/TD]
[TD]mN.m[/TD]
[TD]W[/TD]
[TD]g.cm[/TD]
[TD]mN.m[/TD]
[TD]A[/TD]
[/TR]
[TR]
[TD]13800[/TD]
[TD]0.66[/TD]
[TD]12109[/TD]
[TD]4.6[/TD]
[TD]156.1[/TD]
[TD]15.3[/TD]
[TD]19.4[/TD]
[TD]1253[/TD]
[TD]122.8[/TD]
[TD]32.5
[/TD]
[/TR]
[/TABLE]
