RCU Forums - View Single Post - avonds rafale kit
Old 12-13-2016 | 05:00 PM
c/f
If you find one I have one that was the SWB factory plane 2003? Vintage, that ended up fluttering vertical rudder loose in flight from the internal bulkhead debonding from fuse,Reduced throttle and landed without incident. Bulkhead(s) its all cracked in pieces so if you could send me a traced drawing of internal bulkheads rear of turbine would be great.
I have original manual . Great small field flyer easy to fly and land. Mine was slow 150mph with SWB Mamab, so I reduced inlet size, worked pretty good. Mamba is awaiting return to service.
