As batteries are discharged they generate heat. The more a pack is discharged the hotter it gets so over-discharging can damage a pack in two ways.
While some cells allow a higher higher charge rate, most recommend charging at 1C, for a 3000 mAh pack this means 3 amps. Less just takes longer.
Store LiPos under 80*F.
